CMitchell's avatar
CMitchell
Netgear WNDR3700v2 wireless router
Can anyone tell me if this Netgear wireless router supports a loop back feature.  If so can you tell me how to turn it on? Thanks for the help.
  • Retired_Member's avatar
    Retired_Member
    Oct 19, 2016
    Netgear Wndr3700 OEM firmware doesn't support, see if a 3rd party firmware does.
