NIHill's avatar
NIHill
Network Disappears when connecting wrieless printer via WPS button
I have a WNR2000 v3 router. When I try to set up my wirless printer via push button method, the printer connects, but then my wireless network disappears. In it's place, there is a password protected network called NTGR_iAZIT in it's place. Of course, I don't have a password to log in and see what this is. The only way to get the netowrk back is to reset the router back to factory settings, but then does the same thing when I try to connect the printer.
Is there a way to get my network back without resetting the modem to factory settings? I've removed the printer from the network, but that doesn't help.
Running iOS: Yosemite
Thanks
  • Yes, I had to reset the router to factory settings and then manually set it up. Worked. Just confused becasue auto setup worked great when I first set up the printer earlier in year.
    • NIHill's avatar
      NIHill
