hasanobts
May 26, 2022Follower
Network port capped at 100mbp
I've seen countless threads on this here and none have provided an answer. I have an ARIS Surfboard cable modem SB8200 I have the netgear R6080. When I run a speed test the most I can get is 100mbp...
May 26, 2022Guru - Experienced User
You won't find a way to make it gigabit because its not a gigabit router. Its ports are only 10/100mbps. Not gigabit.
so if you want to hit faster speeds, you need to upgrade to a gigabit router.
- wcalifasMay 26, 2022Prodigy
Yea that router doesn't have the gigabit ports as was stated in the previous post. I read alot of complaints on that model on amazon reviews for that same reason.
- michaelkenwardMay 27, 2022Guru - Experienced User
Is that because the Amazon description is wrong or people are dumb and make the wrong choice?
Looking at the UK site, I see it promises "Faster Wi-Fi - Now up to 1000 Mbps (300 + 700) ". That has nothing to do with the wired speeds, and it in any case misleading marketing rubbish.
