zekgrafic
Jul 21, 2022Follower
New router gives slower speeds
My C6900 router died so I got a CAX30, but my downloads speeds via ethernet went from 50MB/s (megabytes not bits) to a maximum of 20MB/s. The only time this changes is when I unplug the router and plug it in after 30 seconds, then I get a little bit of time with 50MB/s only for it to eventually go back to 20. What is causing this? I pay for 50MB/s download and I'm upset that a NEW router isn't getting it.
1 Reply
The CAX30 should easily max out that connection.
What firmware is on it?
You do get the full speeds after a reboot?
Do you have a screen snip of your cable connections page and the event logs?
