Vmusic's avatar
Vmusic
Follower
Sep 09, 2021
Nighthawk AX4 RAX40v2 ReadyShare Doesn’t Recognize Hard Drive…..DOES Recognize Thumb Drive
Hi,
  I have a new Nighthawk AX4 RAX40 v2 router. I'm running Firmware Version V1.0.2.82_2.0.50.
     In the web admin panel - which is not labeled 'Genie'; it's just labled Netgear and it has a ReadySHARE page/tab.
    I am plugging a SeaGate 2TB external hard drive into it, and when I hit the refresh button, it's NOT recognizing the drive. :smileysad:
   HOWEVER.... if I plug a cheapo thumb drive in the USB 3 port on the back, and click the ReadySHARE refresh link, it DOES recognize the thumb drive.
  I KNOW the SeaGate external hard drive works. It's an NTFS format. I had it connected to a SageCom WiFi router. SageCom (actually Spectrum) removed the web admin pannel, so I could NO LONGER manage the drive. :smileysad: They replaced with an app (as if you really need yet another app on your phone/iPad); and just like the Nighthawk app; there's no controls or interface to manage the USB drive.
SoooOOOOooo back to the problem. Is there a size limit on the external drive that can be connected to the back of a Nighthawk AX4 RAX40???   Are there certain "brands" of external hard drives that are or are NOT supported?
H E L P. ::::  if I can't get the drive to work, I'll take it back to MicroCenter. The ONLY REASON I bought it was for the USB port.
Furious in Philly
1 Reply
