kateew's avatar
kateew
Follower
Dec 31, 2022
Nighthawk not connecting to Daikin adapter
I got a new router (Netgear Nighthawk R6120), and am trying to connect it to my Daikin out of home adapter to operate my air conditioning through the Daikin app.
My iPhone wifi recognises the Daikin AP network and will join with the password, but then says 'No Internet Connection'. I have tried turning the router on and off a couple of times with no luck.
The Daikin app manual says to press the WPS button, but as my router doesn't have a WPS button I'm not sure how else to get them talking to each other.
Thanks to anyone who can help!
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Your subject says:
    " Nighthawk not connecting to Daikin adapter"
    You might do better to think of it the other way round. Daikin adapter not connecting to Nighthawk.
    That's because the router just puffs out the wifi that your adapter has to work with.
    You could start by telling people which Netgear router you are using.
    A more details of that this "Daikin AP network" does might also help.
    All Netgear Nighthawk routers have a WPS button. You just have to find it.
    Look on the top.
    WPS
    Possibly far right, next to this one:
    WPS
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Look for the model number on the label on the device.
