Melita
Apr 24, 2021Follower
Nighthawk router worth it? I will get a modem too
Currently in the market for used modem and routers. I am thinking about getting a night hawk router ac1900 used for cheap under 50 if I can. Then I will probably need a modem too. Now I am pretty ignorant to modem and routers but want something that is good since I am a gamer and plan to use this for a long time. Does it matter what modem and router I buy or can it all be used regardless of the internet providing company?
I will be moving into a new place so need internet.
1 Reply
It needs to be compatible with your isp. Without knowing your isp you don't know if its fibre, dls, cable, etc.
those are key when picking a modem.
Contact the isp and they'll be able to tell you what's compatible or direct you to a list.
It might also be worth checking as some ISP's will give you a free modem versus some charge for a modem.
