rachin99's avatar
rachin99
Follower
Nov 15, 2023
Nighthawk X10 AD7200 R9000 vs. AT&T BGW320
So I have a Nighthawk X10 AD7200 from about 5 years ago and just moved into a new apartment. Signed up for AT&T Fiber and they sent me a new router with installation.
Would the X10 AD7200 be worth setting up or should I just use what was given to me? It's not a huge space but the AT&T BGW320 is inside my bedroom closet...
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Just give it a whirl.
    The R9000 dates back to 2017. With luck the AT&T BGW320 will be a bit more modern on the wifi technology front.
    If you do decide to add the R9000 – to fill a wifi gap, for example –  you can't just plug it into the BGW320. That would put you into "double NAT" territory.
    What is Double NAT? | Answer | NETGEAR Support
    You'd need to do something like Access Point mode with R9000. Or you could play with Bridge Mode.
    To read about those options, visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    But that could get messy. So I'd just try the BGW320.
