gburn
Dec 02, 2017Aspirant
Nighthawk x8 R8300 2.4gHz wifi doesn't have a valid ip configuration error; 5gHz wifi connection ok
Hi,
I bought a Nighthawk x8 AC5000 wifi router (R8300) back in May 2017 and for the past couple weeks my 2gHz band has been giving a "wifi doesn't have valid ip configuration" error. All 5gHz bands are working fine.
I have tried to reset the modem and router, reset my SSID and passwords, reset the router back to factory defaults and have no clue what to do next to fix this issue.
Any help would be greatly appreciated!
Thank you in advance!
Model/Hardware Version: R8300
Firmware Version: V1.0.2.106
GUI Language Version: V1.0.2.106_2.1.46.1
OK. Laptop errors are often down to Windows.Indeed, a Google search shows that the error you see
gburn wrote:
When I run the window's troubleshooter, it produces the "wifi doesn't have a valid ip configuration" error.is pretty common, with various suggestions.
Wifi doesn't have a valid IP configuration - Microsoft Community
But you say that other devices can't connect. I assume that these other wifi clients can see the 5GHz SSID.
You seem to have tried most things. But as this is a router, I would try restarting the whole network according to the rules.
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
Your router is still in warrant – it runs for at least a year – so I'd start going down that road.
gburn wrote:
....for the past couple weeks my 2gHz band has been giving a "wifi doesn't have valid ip configuration" error.
What throws up this error?
- gburnAspirantMy laptop (Windows10). When I connect to the WiFi it indicates that I have no Internet connection. When I run the window's troubleshooter, it produces the "wifi doesn't have a valid ip configuration" error.
None of my devices (any phone or laptop) can connect to the 2.4gHz band; however, they can connect to 5gHz just fine.
I have one laptop, used by my kids, that can only see the 2.4gHz wifi and not the 5gHz one; therefore they cannot get on the Internet wirelessly. Connecting this laptop via ethernet works fine.
I also allow guests to connect to the 2.4gHz and reserve my 5gHz for my wife and I personal devices and now have to allow them to connect to the 5gHz band.
I paid a lot of money for this router and it was working great up to about 2 weeks ago.- michaelkenwardGuru - Experienced User
