adr150
Sep 08, 2015Aspirant
No internet connection - WNDR3700v2
My WNDR3700v2 has mysteriously stopped providing an internet connection. I've gone through the typical troubleshooting steps of doin a power cycle and ensuring that I have a connection directly ...
- Sep 09, 2015
It seems that the router is attempting to get a connection from the Internet. To determine the next step, you need to access the router's GUI and check the WAN Settings.
Using a computer wired to the router, access routerlogin.com. Username is "admin" and the password is "password". Internet connection is not needed since this is just how you get into the GUI. Under Router Status check the IP address under Internet Port. If there's none, you need to reconfigure the router to re-establish the Internet connection. You may follow the steps from the link below to do so.
http://kb.netgear.com/app/answers/detail/a_id/1098/related/1
Daenerys
Sep 09, 2015Luminary
adr150
Sep 09, 2015Aspirant
Thanks Daenerys, that worked!
- DaenerysSep 10, 2015Luminary
You're very much welcome!:womanhappy:
Now that you have Internet connection, I suggest checking for an updated firmware by doing the same steps provided by ElaineM. This is to prevent the problem from happening again.
Have a nice day ahead!
