sabeer6870
Jun 13, 2016Aspirant
No internet connection R6400
Hi , I bought NetGear R6400 4 months ago, suddenly I do not have internet access. Does it means it over?:smileysad: I double checked router is properly connected to modem. And when I connect...
- Retired_MemberJun 14, 2016
use the WIRED PC you tested modem with and login to router...internet setup.....USE PC Mac address....reboot modem....internet led should turn white, if not try disabling IPV6
VE6CGX
Jun 13, 2016Master
See if you can ping the router or manually log into it.
sabeer6870
Thanks for the reply.
How would I ping to router?
I can see 'ember' light for internet on router, that means LAN is connected properly between Modem and Router but no connection.
Would this help to get the better understanding of my situation.
Thanks
- sabeer6870Jun 14, 2016Aspirant
Thanks a lot you are a life saver, it worked I am glad!!!!!!
I owe you a beer :)
