sabeer6870
Jun 13, 2016Aspirant
No internet connection R6400
Hi , I bought NetGear R6400 4 months ago, suddenly I do not have internet access. Does it means it over?:smileysad: I double checked router is properly connected to modem. And when I connect...
- Retired_MemberJun 14, 2016
use the WIRED PC you tested modem with and login to router...internet setup.....USE PC Mac address....reboot modem....internet led should turn white, if not try disabling IPV6
sabeer6870
Thanks for the reply.
How would I ping to router?
I can see 'ember' light for internet on router, that means LAN is connected properly between Modem and Router but no connection.
Would this help to get the better understanding of my situation.
Thanks
Retired_Member
Jun 14, 2016use the WIRED PC you tested modem with and login to router...internet setup.....USE PC Mac address....reboot modem....internet led should turn white, if not try disabling IPV6
- sabeer6870Jun 14, 2016Aspirant
Thanks a lot you are a life saver, it worked I am glad!!!!!!
I owe you a beer :)
