sabeer6870
Jun 13, 2016Aspirant
No internet connection R6400
Hi , I bought NetGear R6400 4 months ago, suddenly I do not have internet access. Does it means it over?:smileysad: I double checked router is properly connected to modem. And when I connect...
- Retired_MemberJun 14, 2016
use the WIRED PC you tested modem with and login to router...internet setup.....USE PC Mac address....reboot modem....internet led should turn white, if not try disabling IPV6
Simarti28
Jul 01, 2016Aspirant
I'm having the same issue. How do you log in to the router when the PC is connected to the modem? The IP address that I retrieved when the router was working does not allow me to log in anymore.
