EliRap
Sep 25, 2019Aspirant
No login possible
Hello, i am new here and i have following problem: When i login into routerlogin.net or http://192.168.1.1 etc and enter, the link will send me to http://homerouter.cpe which is a huwei login, but I...
- Sep 25, 2019
Ok Thanks to your Information that i was connected to the modem, I looked the problem myself up and could solved it :)
The real problem was, that i was using accespoint instead of router, This sadly didnt work before where i was pressing the countinus button like crazy (yes i tried it with more attempts ) without anything happend and the acces point always worked so i thought it was nesscary... But after I changed my ethernet ip to 192.168.1.1 I was also able to click on this one. from there i went to advanced settings but was still not able
to access the internet so I loged out and a login again and it worked.
To be fair I still dont understand it...
Still thanks for your time
EliRap
Its a dial up connection from a dorm
Sep 25, 2019Guru - Experienced User
- EliRapSep 25, 2019Aspirant
A lan wire goes from the port of the wall inte the Router and from there to my notebook.
Should I send I picture of my ipconfig it has somehow 3 diffrent connections.
Btw. this i get when i googel my IP
- plemansSep 25, 2019Guru - Experienced User
so you're in a dorm room with an ethernet wire that is in the wall that you've ran to your router?
I take it you're in school and your school has an IT department that controls the ethernet port in your dorm?
some schools have rules about what is hooked up and if you hook up a router, how they want it setup. If you're running through your schools setup, I'd recommend checking with their IT department so you aren't getting in trouble with their regulations.
Sry for the late respond had to sit down to reflect.
No, the dorm is separate from the school, and many people have an Router.
Also they dont really have an IT-expert. already consulted them and they didn t know,
why it would not connect, but back then i had another problem
First I connected (http://routerlogin.net) I got send to netgear genie page were i clicked on accespoint and then on
ip automatically obtain, which was proposed by the webpage. After that the page loaded and failed
but I could connect to the dial up like there was no Router between so i only had a dial up connection
and Wifi etc. still didnt work.
So I consulted them and they didn t know what to do.
Then i tried itmore often and it worked somehow once and i changed password
but for any login page i had open i got a pop up for the password,
which was the first time it appeard, because it was presaved so I just clicked many times ok,
there was some warning (that the password is wrong or so ) I overklicked while I was clicking
oks (I already sit over 5h to try to solve the problem so i was kind of burned out at that time :/ ),
and the huawei page appeard the first time and the connections failed again more times in a row.
Next day: I reset router, again http://routerlogin.net/ again accespoint... but now
I changed my ethernet Ipv4 too the IP of the Router without any disconnects
but now I only get the huwei page...
