kayla3510
Jun 26, 2017Aspirant
No Wifi Connection
The wifi button will not come on. I have connection via ethernet cord but the wifi will not connect. I have reset router and run all tests on the genie. I have not changed any settings. I was given ...
- Jun 27, 2017
I wonder if Genie is part of the problem I have heard about strange issues when Genie does not play nice.
William10a
Jun 26, 2017Master
Can you log into the router?
Make sure the wifi is enable if you can.
