kayla3510
Jun 26, 2017Aspirant
No Wifi Connection
The wifi button will not come on. I have connection via ethernet cord but the wifi will not connect. I have reset router and run all tests on the genie. I have not changed any settings. I was given ...
- Jun 27, 2017
I wonder if Genie is part of the problem I have heard about strange issues when Genie does not play nice.
William10a
Jun 26, 2017Master
Can you log into the router?
Make sure the wifi is enable if you can.
kayla3510
Jun 27, 2017Aspirant
Yes, I can log in and get access to everything online. The wifi button will not work. It says to enable the wifi hold the wifi button for 3-5 seconds and it will come on. I have done that. I even reset the router. I have held it down for 10-20 seconds. The light will not come on to say the WiFi is working. I went into the Genie settings and it says wifi is turned off. I tried turning it on and it says settings changed but nothing.
- William10aJun 27, 2017Master
