kayla3510
Jun 26, 2017Aspirant
No Wifi Connection
The wifi button will not come on. I have connection via ethernet cord but the wifi will not connect. I have reset router and run all tests on the genie. I have not changed any settings. I was given ...
- Jun 27, 2017
I wonder if Genie is part of the problem I have heard about strange issues when Genie does not play nice.
kayla3510
Jun 27, 2017Aspirant
Yes, I can log in and get access to everything online. The wifi button will not work. It says to enable the wifi hold the wifi button for 3-5 seconds and it will come on. I have done that. I even reset the router. I have held it down for 10-20 seconds. The light will not come on to say the WiFi is working. I went into the Genie settings and it says wifi is turned off. I tried turning it on and it says settings changed but nothing.
William10a
Jun 27, 2017Master
