kayla3510
Jun 26, 2017Aspirant
No Wifi Connection
The wifi button will not come on. I have connection via ethernet cord but the wifi will not connect. I have reset router and run all tests on the genie. I have not changed any settings. I was given ...
- Jun 27, 2017
I wonder if Genie is part of the problem I have heard about strange issues when Genie does not play nice.
kayla3510
Jun 27, 2017Aspirant
It will not let me do that. It says the WiFi button on the router needs to be enabled before I can select that. The button does not light up at all. I've held to from 3-20 seconds. I just reset up the router and still doing the same. The button will not light up or blink. Literally nothing.
