Fumanchu1021
May 29, 2021Aspirant
No WiFi connection
I started having this issue last week and have never encountered this before. If I’m outside my house and I connect to the Orbi through the app via “connect anywhere access” it says it’s online & connected to Internet and all my home devices are connected as well. At my house, none of my devices are actually connected, though some still say they are. E.g. when I turn on my Vizio smart TV, it says no network detected on the screen, but in the menu bar, it says it’s connected to WiFi and when I test the connection it says it works. My Google home hub says it’s not connected to WiFi but on the orbi app it says it is. Can anyone help?
1. What actual orbi do you have?
2. what firmware is on it?
3. what gateway/modem is it connected to?
- Fumanchu1021AspirantIt’s an Orbi AC3000 mesh router with one satellite. Firmware is V2.7.2.104 and connected to Motorola MB8600 modem.
on the orbi, try disabling daylight savings time and then the traffic monitor. then reboot the router.
there's been a lot of posts about the .104 firmware.
did this just start? was it working before?
