phonore
Apr 17, 2016Aspirant
Not in range error
Router has been working great for ~10 years. Now, no wireless devices (smart phones, tablets) can logon. Can see networks but "not in range" error appears for my network, (router is approximately 2 ft away). Hard wired devices (desktop, printer) still work and access the net with no problems. Powered off (unplugged power) and back on. Same result.
I did a "factory reset" and that fixed the problem (plus I now know the admin password since I got to re-establish it). Thanks to all for the help
- ElaineMNETGEAR Employee Retired
- VE6CGXMaster
I'd download and run inSSIDer or Acrylic WiFi survey utility to see the status of signal. Could you try
another WiFi device, not the one you tried already.
- phonoreAspirant
Tried an Iphone, an android phone and an android tablet - same result. Phones aren't here right now and can't download Acrylic to tablet without wi-fi. My desktop is hardwired to the router and works fine but won't work with Acrylic. Thanks for trying
- VE6CGXMaster
There is a possibility radios are dying. Any failure can happen any time. Normal working router even with antenna
disconnected can give better signal than that. Try after f/w reflash maybe to confirm.
