jeffsteinberg2
Jul 17, 2017Follower
Obi VOIP ports
My Obi200 VOIP adapter needs the following ports open to work.
Allow Outgoing:
TCP Ports: 6800, 5222, 5223
UDP Ports: 5060, 5061, 10000 to 11000, 16600 to 16998, 19305
Allow Incoming on UDP Port: 10000
The terminology above is not the same as the terminology in the router's setup. How do I set up the router to allow my device to operate? I understand that I need a static IP address for the device, and I have assigned one to it.
Hi jeffsteinberg2,
We recommend doing address reservation and then do the port forward. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/24091
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi jeffsteinberg2,
Dexter
Community Team
Hi jeffsteinberg2,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
