amberlynn4's avatar
amberlynn4
Follower
Dec 13, 2022
Older router N750
I have an older router - N750.  Until a few days ago everything worked fine.  All device stopped connected, but I was able to go in and re-add them; however, now I can only connect to Netgear 10 and Netgear 10 guest, not my Netgear 5g.  It is visible but when I enter the password it says it is incorrect.  Nothing has been changed or updated.  What can I do to resolve?
1 Reply
  • plemans's avatar
    What actual router do you have? n750 is a speed.
    Have you tried a factory reset ?
    What modem/gateway is it connected to?
    Does they device with issues have 5g capability? What device is it?
