ngmaa
Aug 08, 2016Aspirant
On Networks n300r ddwrt
Hi! I'd like to flash an open source software on the On Networks N300R. DDWRT works great on the N150, albeit an old version of DDWRT. Can anyone tell me an open source firmware available for t...
- Aug 17, 2016
ngmaa I apologize but the only information I can give is the product's manual and the unit has been EOL for a long time.
http://www.on-networks.com/products/routers/n300.aspx
Now, regarding the equivalent product model of this On Networks, you may want to check WNR2000v5. Somehow, that's the closest model number that is similar to N300R.
When it comes to using 3rd party, we do not support and recommend the use of 3rd party firmware because it will void the warranty.
ngmaa
Aug 11, 2016Aspirant
The following information is printed on the outside...
On Networks N300R.
FCC ID PY310400149.
Also lists N10947 Z1067
And 272-11441-02
On Networks N300R.
FCC ID PY310400149.
And 272-11441-02
- ElaineMAug 17, 2016NETGEAR Employee Retired
