geofmill's avatar
geofmill
Only one router
Have 6220 modem-router-wi-fi (wi-fi disabled). Using Orbi system to distribute Wi-fi in house. Is there a way to disable D6220 router and use the more updated Orbi router? Everything updated to late...
  • antinode's avatar
    antinode
    Oct 03, 2019
    > Yes, using dsl modem. PPPoE.
       Ok.  Then you should be able to configure the D6220 as a modem-only,
    and configure the PPPoE credentials on the Orbi router (whatever its
    model number might be).
    > Since I updated entire Netgear system 3 days ago, all 6 pieces are up
    > to date.
       "up to date" tells me no more than "latest" did.  Any (unfortunate)
    future readers will find it even less helpful.
    > I already checked documentation and there is no listed method for
    > disabling the router.
       Which "documentation"?  When I looked at the D6220 User Manual, I
    (easily) found the section whose heading I quoted above.
