geofmill
Oct 03, 2019Aspirant
Only one router
Have 6220 modem-router-wi-fi (wi-fi disabled). Using Orbi system to distribute Wi-fi in house. Is there a way to disable D6220 router and use the more updated Orbi router? Everything updated to late...
- Oct 03, 2019
> Yes, using dsl modem. PPPoE.
Ok. Then you should be able to configure the D6220 as a modem-only,
and configure the PPPoE credentials on the Orbi router (whatever its
model number might be).> Since I updated entire Netgear system 3 days ago, all 6 pieces are up
> to date."up to date" tells me no more than "latest" did. Any (unfortunate)
future readers will find it even less helpful.> I already checked documentation and there is no listed method for
> disabling the router.Which "documentation"? When I looked at the D6220 User Manual, I
(easily) found the section whose heading I quoted above.
geofmill
Thanks for reply’s.
Since I updated entire Netgear system 3 days ago, all 6 pieces are up to date.
I already checked documentation and there is no listed method for disabling the router.
Looking forward to more input.
Thanks.
Thanks.
- antinodeOct 03, 2019Guru
