scoberch's avatar
scoberch
Open portal for cellular range extender
Hello, I have a Samsung 3g cellular network extender from Verizon that I need in my home since my cell reception is terrible. It’s worked in the past on a previous Netgear product, however I recent...
  • DexterJB's avatar
    DexterJB
    Oct 19, 2017
    Hi scoberch,
    Yes, it is not recommended to leave a device on DMZ. It is just one way for us to isolate the issue. What this means is that there may be one or more ports that needs to be forwarded/configured for the cellular range extender. We suggest contacting your ISP and/or the manufacturer.
    Dexter
    Community Team
