scoberch
Oct 05, 2017Aspirant
Open portal for cellular range extender
Hello, I have a Samsung 3g cellular network extender from Verizon that I need in my home since my cell reception is terrible. It’s worked in the past on a previous Netgear product, however I recent...
- Oct 19, 2017
Hi scoberch,
Yes, it is not recommended to leave a device on DMZ. It is just one way for us to isolate the issue. What this means is that there may be one or more ports that needs to be forwarded/configured for the cellular range extender. We suggest contacting your ISP and/or the manufacturer.
Dexter
Community Team
DexterJB
Oct 15, 2017NETGEAR Moderator
scoberch
Oct 16, 2017Aspirant
Hello,
This didn't work. Looking at the setting Verizon has listed, is there anything else you'd recommend:https://www.verizonwireless.com/support/network-extender-router-configuration/#netgear
Thanks,
Scott
