scoberch
Oct 05, 2017Aspirant
Open portal for cellular range extender
Hello, I have a Samsung 3g cellular network extender from Verizon that I need in my home since my cell reception is terrible. It’s worked in the past on a previous Netgear product, however I recent...
- Oct 19, 2017
Hi scoberch,
Yes, it is not recommended to leave a device on DMZ. It is just one way for us to isolate the issue. What this means is that there may be one or more ports that needs to be forwarded/configured for the cellular range extender. We suggest contacting your ISP and/or the manufacturer.
Dexter
Community Team
scoberch
Oct 18, 2017Aspirant
Dexter,
That looks like it worked! Is there any security risk that I should be aware of based on the warning in the link you sent?
Thank you,
Scott
DexterJB
Oct 19, 2017NETGEAR Moderator
Hi scoberch,
Dexter
Community Team
