Rickwur's avatar
Rickwur
Opening ports and public ip
Have a orbi 6 rbk753 ax4200
Trying to network to my defender security system . Need to open ports 80,5000,9000,18004
Told ip is private needs be public
Please help
  • > Have a orbi 6 rbk753 ax4200
       Connected to what?
    > [...] Need to open ports 80,5000,9000,18004 [...]
       Says who?  For outgoing connections (no action needed), or for
    incoming connections (unlikely, port forwarding might be needed).
    > [...] Told ip is private needs be public
       With my weak psychic powers, I can't see it from here.  Point a web
    browser at the management web site of your router, and report what you
    find at: ADVANCED > ADVANCED Home : Internet Port : Internet IP Address.
    Plug that address into the form at: https://whois.arin.net/ , and see if
    it is a public or private address.
       The usual cause for that to be a private address would be connecting
    the RBK753 router to some other router -- either a device on your
    premises, or one at your (unspecified) ISP, if they use carrier-grade
    NAT.
          https://en.wikipedia.org/wiki/Carrier-grade_NAT
    • Rickwur's avatar
      Rickwur
      rbk is conected to a spectrum modem
      I can view my camers home with a app on my phone (defender clear vu ) wifi but not away .
      working with net gear tech we were able to open the ports needed told me possibly the ip adress 172. is private and not public a class B .
      thanks any thoughts
      • antinode's avatar
        antinode
        Guru
           Thanks for the details.  So, if I plug "a spectrum modem" into my
        search engine, I'll get all the information about _your_ modem?
        > [...] told me possibly the ip adress 172. is private and not public a
        > class B .
           From "172.", I can't tell.
           You can see that address, and I can't.  Which of us, do you think,
        should try that experiment?
        > [...] or one at your (unspecified) ISP, if they use carrier-grade NAT.
           Ask your ISP?
