kman5574
Nov 12, 2022Tutor
opening ports on Nighthawk R6330
Hi, I need some help with opening ports on my router. I have a rowing machine that's been connected to the internet
since I got it 3 months ago with no issue. Last week I couldn't get it to connect on my network but it would connect using my hotspot. Their tech support wanted me to open ports HTTP 80 and HTTP 7350 thinking that might be the issue. I've gone into Port Forwarding and tried to add them but not sure if I'm doing it correctly. Any help would be appreciated.
Have you tried a different dns provider? Or enabling ipv6?
Try a different DNS Server. Here's a few for ipv4. Also remember to change the ipv6 dns server if ipv6 is enabled
CloudFlare 1.1.1.1 and 1.0.0.1
GoogleDNS 8.8.8.8 and 8.8.4.4Does it connect to the wifi but just not find an internet connection?
Did anything change with the router during that process?
What rowing machine is it?
What modem/gateway is your router connected to?
