jj77669
Dec 17, 2020Aspirant
Opening ports RBR40
I have a RBR40.
I just need to open 1 port. No matter how hard I try...nope.
I have followed every guide. Go to advanced settings, list the number and the device.
Unblock in Windows firewall, update firmware.
I only have a modem and a router. The modem is not a router.
Could someone please tell me what I am doing wrong?
I now have more gray hair than when I started.
> I just need to open 1 port. [...]
Which? Why?
> [...] No matter how hard I try...nope. [...]
None of that is a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.> [...] I have followed every guide. [...]
"every'? Thanks for the helpful links.
Someone who knew what you were doing might have some kind of chance.
So far, that excludes me.
In my experience, people who talk about ports being "open" or
"closed" often don't understand the problem.For the usual problems with port forwarding, see:
- jj77669Aspirant
Which? Why?
1194 for OpenVPN
Filled in port forwarding according to Netgear's instructions.
Also followed guide from NoIP...same result.
Used a port checker to test the port...still closed.I have done this before using a Linksys router, with no issues.
> 1194 for OpenVPN
Where is this OpenVPN running? How did you intend to connect to it?
From where?
And if someone with my weak psychic powers could guess which of
"Netgear's instructions" you were reading, and what you actually did
with them, then that (non-)description might have some actual value.> Also followed guide from NoIP...same result.
Thanks for the helpful link. Now you've followed two different
guides, both invisible. You could just post blank messages, and I'd
learn as much.See "As usual, [...]", above. Which part of "actual" was unclear?
Swell. I can't see what you did then, either.
> https://community.netgear.com/t5/x/x/m-p/1859106I see no answers to any of the questions there. My time is much more
valuable to me than it seems to be to you.
