like2trip
Jul 26, 2017Follower
OpenVPN not working on r6400
So I have gone through the steps as listed in the help articles for setting up open vpn on the router, however it never connects, and to be honest somewhat lost as to what i need to do. long strings of things saying disabled or undefined. I also get the following warning
WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Wed Jul 26 13:34:53 2017 Re-using SSL/TLS context
Wed Jul 26 13:34:53 2017 LZO compression initializing
Wed Jul 26 13:34:53 2017 Control Channel MTU parms [ L:1654 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Wed Jul 26 13:34:53 2017 MANAGEMENT: >STATE:1501090493,RESOLVE,,,,,,
Wed Jul 26 13:34:53 2017 Data Channel MTU parms [ L:1654 D:1450 EF:122 EB:411 ET:32 EL:3 ]
Wed Jul 26 13:34:53 2017 Local Options String (VER=V4): 'V4,dev-type tap,link-mtu 1590,tun-mtu 1532,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client'
Wed Jul 26 13:34:53 2017 Expected Remote Options String (VER=V4): 'V4,dev-type tap,link-mtu 1590,tun-mtu 1532,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-server'
Wed Jul 26 13:34:53 2017 TCP/UDP: Preserving recently used remote address: [AF_INET]98.24.233.14:12974
Wed Jul 26 13:34:53 2017 Socket Buffers: R=[65536->65536] S=[65536->65536]
Wed Jul 26 13:34:53 2017 UDP link local: (not bound)
Wed Jul 26 13:34:53 2017 UDP link remote: [AF_INET]98.24.233.14:12974
Wed Jul 26 13:34:53 2017 MANAGEMENT: >STATE:1501090493,WAIT,
an yes I have gone to the link which doesn't help because no clue what it is talkign about. The instructions for the router give no help as it assumes you follow the directions and it works so no steps provided when it doesn't
Hi like2trip,
Please make sure that you have followed the steps in setting up the OpenVPN including copying the config files to the designated folder. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23854
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi like2trip,
Dexter
Community Team
