MMERIDETH
Sep 21, 2018Aspirant
OPENVPN will not connect
For whatever reason, had vpn working last week and now it does not. have tried everything i can find but am unclear what a PK1 is and if I need it. connecting thu xfinity business modem/router with port forwarding. really at a loss on what to do next. Thanks!
Get this and it keeps going
Fri Sep 21 09:06:07 2018 us=888576 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info
Then later this
Fri Sep 21 09:06:09 2018 us=401779 TLS: Initial packet from [AF_INETdeleted for privacy
Fri Sep 21 09:06:10 2018 us=524981 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, [email protected]
Fri Sep 21 09:06:10 2018 us=524981 VERIFY OK: depth=0, C=TW, ST=TW, O=netgear, OU=netgear, CN=netgear, [email protected]
Fri Sep 21 09:06:10 2018 us=930582 Connection reset, restarting [0]
I am lost. Thanks!
V1.0.4.18_10.1.49
I got it to work.
Ended up turning the VPN off
restarting router
turning VPN back on
downloading new cert information
installing new files on client
works fine at least for one computer
working on another computer today
Thanks!
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.- MMERIDETHAspirant
V1.0.4.18_10.1.49
I got it to work.
restarting router
turning VPN back on
Thanks!
Well done. I asked about the firmware because Netgear recently released a bunch of updates that accommodate changes in support for VPN.
You have the latest version, so your R8000 should work with OpenVPN:
R8000 Firmware Version 1.0.4.18 | Answer | NETGEAR Support
