Retired_Member's avatar
Retired_Member
Oct 09, 2015
OpenVPN with iOS
Brief history: I upgraded to Cox Gigablast and they included a Netgear R6300v2.  I had a VPN on my previous router (ASUS Dark Knight) that I used for conneting securely in places that aren't secure.  Coffee shops, airports, etc.
Trying to setup the is OpenVPN vpn on the router and I have it all setup with a DynamicDNS service and everything.  Downloaded Certs and OVPN file and imported into iPhone.  Open up the OpenVPN app and import in the profile.  It gives the following error: "iOS doesn't support TAP-based tunnels"
In doing research, apparently I have to setup a TUN based vpn so that it will work with IOS.  Is there a way for me to switch this vpn tunnel to a TUN based type?  I can't seem to find a setting for that.  Any help would be greatly appreciated.  Thank you!
  • storm1985's avatar
    storm1985
    Oct 14, 2015
    It doesnt support OpenVPN for iOS or Android. You should see the highlighted options below if R6300v2 does support Smartphones.
  • Are you using a NETGEAR firmware? I dont think R6300v2 has openVPN feature.
    • Retired_Member's avatar
      Retired_Member
      It does.  Under advanced tab, advanced setup.  You have to setup a DynamicDNS obviously and then turn on the VPN option.  Screen Shot 2015-10-14 at 1.27.56 PM.png
