vt15
Apr 01, 2025Aspirant
Orbi and netgear ac1750 r6350, verifying my config is correct
Hello,
I have an old Orbi with one remote station, and I added a netgear ac1750 to my network to extend the reach of my orbi and have some ports for wired connection of a desktop.. I have a device physically cabled to the orbi remote, so that orbi remote and orbi router did not change as the device has to be plugged in to my orbi remote.
I connected my provider's modem to the Orbi yellow internet port, and I connected one of its 4 LAN ports to one of the 4 LAN ports on the netgear.
I can connect to the internet via wifi by connecting to either the orbi or the netgear. I can also cable computers to the remaining 3 ports on the netgear, so all is good there.
However there are some problems.
1: My wireless printer is not reachable - regardless of which wifi access point I am connecting it to. the hp app says it is in the cloud vs on the LAN and has reduced functionality. It shows on the orbi website as having a IP address in the 192.168 range.
2 I can connect to the orbi via a browser but cannot connect to the netgear via the browser or a mobile app. the mobile app doesnt accept default credentials. I have done a reset, and got in but when I tried to login as admin or reset the admin password to something new it failed saying "cannot connect to the network:.
3) the orbi shows the netgear as a connected device with 192.168.1.1
My questions are:
1) Is this the correct cabling for what I am trying to do.
2) Do I need to disable something on the netgear so it doesn't make 2 networks? If so how do I connect to it. I have tried by using my computer and switching off wifi and connecting it with a cable to the netgear but it also didn't work.
Many thanks in advance for your help.
1 Reply
vt15 wrote:
I have an old Orbi with one remote station, and I added a netgear ac1750 to my network to extend the reach of my orbi and have some ports for wired connection of a desktop..Is this AC1750 the R6350 in your subject. (Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.)
If so, is it in access point (AP) mode?
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
That is how to get rid of the double NAT issue that seems to be troubling you.
What is Double NAT? | Answer | NETGEAR Support
Disclaimer: Just another user with time on their hands.
