DuckFans10's avatar
DuckFans10
Orbi RBR 750 not found after factory default reset
Hello,
I reset my Orbi to remove Xerox to refresh then the system is completely refresh. I tried new setup system then Orbi is not found. I tried searching for information that help with Orbi not found, so I followed every instruction and did not find the way to access. I tried resetting the modern and Orbi. I also tried using WiFi connect to Orbi app. I tried 20 times, so I am in the bind here.
  • I have a question. I found my RBR750 is disconnected on my Orbi app. Should I log on PC to turn it back on? This is my first time doing Manuel fix word on router. So can I have any advice on what should I do?
    • DuckFans10's avatar
      DuckFans10
      I managed to get back into Orbi. I would not call this a trick at all. I used factory reset and manuel the Orbi app on iPhone 8. As soon I saw the WiFi up, it does some cut in, but I only need a signal on my phone. So I jump to Orbi app and it skip not found and I am in firmware searching. It show error so I decide to skip straight to end. I got in and check if I can reboot firmware and I cannot. Somehow, it automatically update itself already. I guess I am okay.
