lyrussel's avatar
lyrussel
Initiate
Mar 14, 2020
Orbi RBR40 Firmware Update
I got an email this morning saying that a new firmware update is available - Latest firmware version: v2.3.5.34.  I logged on to my Orbi and it says it is running V2.3.5.30.  So I click on check button and it says "No new firmware version available."
Any ideas how I can upgrade to the latest?
  • Same here, RBR20 current at .26, email says .36 available, both web login and app say 'no new firmware updates'
    • antinode's avatar
      antinode
      Guru
         Or almost any other...
         Visit http://netgear.com/support , put in your model number, and look
      for Downloads. (For older versions, under Firmware and Software
      Downloads, look for "View Previous Versions".)  Find the kit(s).
      Download the kit(s) you want.  Read the "Release Notes" file for
      instructions.
         "Beta" or "Hot Fix" versions typically will not be applied by the
      automatic update scheme.
