hezahonker
May 22, 2017Aspirant
Palm TX connects to guest but cannot surf or fetch mail
I realize this is an old device that requires a 802.11b. However, it shows this router is backwards compatible with b. I have been able to connect the TX only through guest network. It has been assig...
- May 23, 2017
I agee. It just needs a good old fashion b router and I am sure it will be very happy. However, for now, I have the guest channel allowing me to surf which is a start. Once I have a b router, I bet it will all work. Thanks again for your time and have a pleasant day.
doraemon
May 23, 2017Prodigy
That's correct.
It may also just probably need that B router or an access point just like back in the days.
hezahonker
May 23, 2017Aspirant
- doraemonMay 23, 2017Prodigy
You are welcome and hopefully it will work.
