Gregthree3
Feb 26, 2018Aspirant
Parent Control based on Network logged in on R6400
Looking for some assistance. I want to set up my dual band Router with my wife and I on one band and my kids on the other. I then want to set up the parent controls on the kids band to prevent them f...
- Mar 01, 2018
Hi Gregthree3,
1. Yes, it is possible. However, using separate bands for you and your kids may be an issue since you may have devices that do not support both bands.
2. You can check the link below for an overview on the difference between the 2.4GHz band and 5GHz band.
http://kb.netgear.com/app/answers/detail/a_id/29396/
3. As for LPC (Live Parental Controls), you can set it up with linked instructions below.
http://kb.netgear.com/app/answers/detail/a_id/25687
Dexter
Community Team
DexterJB
Mar 01, 2018NETGEAR Moderator
Hi Gregthree3,
Dexter
Community Team
DexterJB
Mar 04, 2018NETGEAR Moderator
Hi Gregthree3,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
