route123
Sep 13, 2021Aspirant
parent control not working recnetly
Hello,
parent control in my router worked all the time till a couple of days ago.
nothing is chagned for the device except I changed from netgear modem to xfinity cable modem recently. I am not sure if it is related or not.
I checked the DNS servers are correct:
208.67.222.123
208.67.220.123
the parent control in opendns login is set as Moderate which blocked all adult websites
Any suggestions to fix the problem?
Model: WNDR3700v4|N600 Wireless Dual Band Gigabit Router
1 Reply
route123 wrote:
Hello,
Which sort of parental controls? (There are three, at least, that I know of.) The freebie?
It is on its way out. Recent firmware updates have already removed this feature from several routers and apps. More may be on the way.
Netgear has just announced that it is killing the free Live Parental Controls. So don't get to rely on it.
NOTICE: Live Parental Control Service based on Ope... - NETGEAR Communities
Something as old as the WNDR3700 range, first launched in 2010, may not get new firmware, but that won't save it from the shutdown.
