Johnrodgers0712
Feb 25, 2018Aspirant
Parental Controls
I log into router and select Parental Controls. It ask me to download Genie. I download it and run it. I get to the "Checking Router Firmware" page and I have waited up to an hour and a halh with the...
- Mar 01, 2018
Hi Johnrodgers0712,
Please make sure you follow the steps on the link below.
http://kb.netgear.com/app/answers/detail/a_id/25687
You may also try using a mobile device (iOS or Android).
Dexter
Community Team
DexterJB
Mar 01, 2018NETGEAR Moderator
Hi Johnrodgers0712,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
DexterJB
Mar 05, 2018NETGEAR Moderator
Hi Johnrodgers0712,
Dexter
Community Team
