robboyd
Nov 13, 2020Aspirant
Password reset or retrevial
I moved into a new, larger home and my wifi through out the house sucks. I found this old router when unpacking but cannot remember the password.
I have searched on youtube but can't find the ACTUAL website to goto to reset without being sent to some nighthawk thing. I know my router is old but can it be reset and how?
The model is N300 wnr2000 v3...wont find in the above
> I have searched on youtube [...]
For _what_? Did you try anything simple, like, say, a simple Web
search for terms like, say, "netgear lost password"?Here's another radical concept:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the Setup Manual (at least). Read. Look for
"Restoring the Default Password and Configuration Settings". It's not
complicated.- robboydAspirant
Thank you.
Will be the first and last time I use the "community" as a resource, since smartass responses seem to be the go-to.
> Thank you.
Glad to help. You did get the desired information, right?
> [...] smartass [...]
As we said when _I_ was a child: Better smart than dumb.
