cja59uk
Apr 25, 2021Aspirant
Pi-Hole using RBK352 — Orbi AX1800 WiFi 6 Dual-band Mesh System 2 pack
I am having trouble getting pi hole to work using Orbi Mesh. I followed an article which said that you can either just set up and use the pi-hole DNS server or also use DHCP on the pi-hole. If I do the later it really messes up the whole system and the only way back was to do a fresh install of the Orbi system. (I couldn't even access the router via either the app or web page) However if I " Use These DNS Servers" and set the primary and secondary to the IP of the pi-hole my connection to the internet goes off. Any ideas
1 Reply
- cja59ukAspirant
It seems that the only way to get this to work is to set the secondary DNS Address to: 8.8.8.8 which I think is Google.
