Pgafric
Jul 12, 2017Initiate
PIN Code Location on Router
I am trying to register another pc on my N300 WiFi router but it tells me to enter the 8 digit pin on the router display. Does anyone know where this 8 digit number is located?
michaelkenward
Jul 13, 2017Guru - Experienced User
Which N300? That's a wifi speed not a router model.
You should not need the PIN number, if you can use WPS, but you should be able to find it in the WPS Settings pages of your device's controls.
Where you'll find that depends on the model number (see above). On my device it is >> Advanced >> Wireless Settings.
