Pgafric
Jul 12, 2017Initiate
PIN Code Location on Router
I am trying to register another pc on my N300 WiFi router but it tells me to enter the 8 digit pin on the router display. Does anyone know where this 8 digit number is located?
Pgafric
Jul 13, 2017Initiate
I'm sorry, I meant to say I have model WNR2000v5. I went into advanced and wireless and tried using the code listed there but this pop up keeps telling me I have to put in an 8 digit PIN that is on the router and there isn't a PIN number on there. I called the technical team but they want to charge me $149 to fix it and I can buy a new one for $40 but would prefer to fix the one I have if anyone has an answer? Thank you to anyone who may be able to help.
William10a
Jul 14, 2017Master
A 8 digit code is generally used by the wps of the router and device yur are trying to connect to it are you trying to use wps when connecting the other computer?
If by wifi normally you just have to find your ssid of your network you want to use and when you tell the computer too log into you will be asked for the passphrease you set the wifi for once enter the computer should remember it.
