Tripl3j
Sep 08, 2021Aspirant
PLW1000 / mywifiext Issues
I am having a strange issue..... 1) My ISP used to have two networks avaiable on the wifi network. - 2G Network - 5G Network - I was able to get the PLW100 conn...
michaelkenward
Sep 09, 2021Guru - Experienced User
Tripl3j wrote:
The modem and router router come from my ISP.
If you want help fixing problems, we still need to know what this modem and router is/are.
Tripl3j wrote:
They control that all, they determine what networks the PLW100 can see, and can access.
Unlikely, but without more information we are all left guessing.
Sounds like you need to talk to your unnamed ISP. There is nothing that Netgear can do about things that are beyond your and its control.
Tripl3j
Sep 09, 2021Aspirant
I private messaged you my ISP, I redacted it from here, for security purposed lol......
The modem is a Ubee EU2251
Router is a Askey SAX1V1K
Both are branded Spectrum also.
I have spoke with them about this in the past, you know how that goes lol, are they even Tech's? But I have been told they control the networks, that are available. Their company name is even in the "default" network name. I must go in and change it.
- michaelkenwardSep 09, 2021Guru - Experienced User
It looks like the Ubee EU225 is a plain cable modem. The Askey SAX1V1K (or is it SAC1V1K or RAC2V1K?) is a standard router.
I doubt very much if your ISP has much "remote control" over the router, the important bit. (It can manage modems, but that shouldn't get at the router.) You should be able to access the router from a PC so that you can change its settings.
The usual way into a router is with a browser to:
The symptoms you describe, two wifi SSIDs suddenly becoming a single SSID, can happen when "smarty connect" is activated.
As to the PLW1000, you need to get into its "management". If www.mywifiext.net does not work, then you need to find the IP address that is has picked up from the router.
There are various ways of getting the IP address. The easiest is to get into the router and see which IP address it has assigned. If that doesn't work, then whatever you use to access the wifi should also have a way of finding the "properties" of the IP source from the PLW1000.
- Tripl3jSep 09, 2021Aspirant
Thank you for your time.
1) I already have the IP for the PLW1000, when I type that into a browser, it spins, and spins. It cannot connect. It returns errors.
2) I can access my ISP provided modem, and router, without issues. I can see the IP's, via IPCONFIG, or I can see via the ISP app.
3) It is SAC, not SAX, apologies.
4) I have not seem a "smarty connect" option. It wasnt there before the fimrware update (to the ISP provided modem).
After the firmware update to the ISP modem, I was kicked off all networks, and all devices. I had to go back in, and re-setup all that information. Only this time, 1 SSID. instead of 2.
Also, as I mentioned, my ISP had restriced acess to making changes via the desktop. It is blocked. You must use their app now.
