kbguay123's avatar
kbguay123
PLW1000v2 firmware
I have a netgear PLW1000v2 & the powerline that comes with it. i am trying to uodate the firmware becasue i have not done it since i bought it in 2018. no where in the user manual does it give directions as to hwo to do it, please help.
also, my mom bought a new router and i had to reset the products to the new router and ever since then i cant connect my xbox to the extender. worked fine before. was thinking maybe i need to update the firmware? idk what else to do bc i am not good with tech. at all. thank you
  • > [...] no where in the user manual does it give directions as to hwo to
    > do it, [...]
       Visit http://netgear.com/support , put in your model number, and look
    for Downloads.  (For older versions, under Firmware and Software
    Downloads, look for "View Previous Versions".)  Find the kit(s).
    Download the kit(s) you want.
       Normally at that point, you'd read the "Release Notes" file for
    instructions.  Sadly, the Release Notes file for the latest (V1.0.0.18)
    firmware for the PLW1000v2 says only:
          [...] follow the instructions in your product's user manual. [...]
    and "firmware" seems not to be mentioned in the User Manual for
    "PowerLINE 1000, 1010 and 1200 Adapters".
       Interestingly (and perhaps usefully), the Release Notes for the
    earliest few firmware versions do include some more useful instructions.
    > [...] my mom bought a new router and i had to reset the products to
    > the new router [...]
       That tells me approximately nothing about what you did.
    > [...] and ever since then i cant connect my xbox to the extender.
       Similarly useless.  First, "cant" is a word, different from "can't".
       "can't" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
    > [...] worked fine before. was thinking maybe i need to update the
    > firmware? [...]
       I wouldn't bet on that.
    > idk what else to do [...]
       You might try a settings reset on your Powerline gizmos, and then
    pretend that they're new.
    for Documentation.  Get the User Manual (at least).  Read.  Look for
    "Reset".  Further reading might not hurt, either.
    • kbguay123's avatar
      kbguay123
      I already reset it and it did not fix the issue I am having. But, thank you for your reply.
      • antinode's avatar
        antinode
        Guru
        > I already reset it [...]
           "it"?  What about the other one?  You do have two Powerline gizmos,
        right?
        > [...] and it did not fix the issue I am having. [...]
           A settings reset is not a magical panacea.  "pretend that they're
        new" meant to follow the set-up instructions as if they were new.  It
        did not mean that the gizmos would magically configure themselves.
           With my weak psychic powers, I still can't see what you did, or what
