buchtik
Jun 12, 2016Tutor
Port Forwarding - communication outside of the rules
Can someone explain to me - the external communication (no asked) outside the rules of redirection to LAN network - the firewall does not work ? Port forwarding rules: 1 DMS B ...
- Jun 12, 2016
Hang on, you have two port forwarding rules allowing ports 80 and 443 through.
5 Topfield 8080 8080 80 80 192.168.2.111
7 https 443 443 443 443 192.168.2.110And that's exactly what your latest logs show.
TheEther
Jun 12, 2016Guru
Do you have UPnP enabled? If so, check the UPnP table to see what additional ports have been opened.
buchtik
Jun 12, 2016Tutor
where exactly do I find these settings? Search UPnP settings in help is not successful ...
- buchtikJun 12, 2016Tutor
Sorry I am stupid ... yes UPnP is allowed - I ban it and refer result
Hi, UpnP is denied ani in records - a little better - also are at odds with routing rule.
Target port is ready but source port is bad. It are ping ? - answer for ping is denied ...
LAN access from remote] from 46.174.37.238:1795 to 192.168.2.110:443, Sunday, Jun 12,2016 19:57:54
[LAN access from remote] from 220.254.153.173:51422 to 192.168.2.110:443, Sunday, Jun 12,2016 19:55:48
[LAN access from remote] from 220.254.153.173:52885 to 192.168.2.110:443, Sunday, Jun 12,2016 19:55:48
[LAN access from remote] from 84.55.49.180:28947 to 192.168.2.110:443, Sunday, Jun 12,2016 19:55:37
[LAN access from remote] from 84.55.49.180:56721 to 192.168.2.110:443, Sunday, Jun 12,2016 19:55:37
[LAN access from remote] from 180.97.106.161:37269 to 192.168.2.110:21, Sunday, Jun 12,2016 19:53:53
[LAN access from remote] from 24.71.26.5:58073 to 192.168.2.110:443, Sunday, Jun 12,2016 19:53:28
[LAN access from remote] from 24.71.26.5:53881 to 192.168.2.110:443, Sunday, Jun 12,2016 19:53:28
[LAN access from remote] from 83.7.78.215:49586 to 192.168.2.110:443, Sunday, Jun 12,2016 19:53:16
[LAN access from remote] from 83.7.78.215:5061 to 192.168.2.110:443, Sunday, Jun 12,2016 19:53:16
