buchtik
Jun 12, 2016Tutor
Port Forwarding - communication outside of the rules
Can someone explain to me - the external communication (no asked) outside the rules of redirection to LAN network - the firewall does not work ? Port forwarding rules: 1 DMS B ...
- Jun 12, 2016
Hang on, you have two port forwarding rules allowing ports 80 and 443 through.
5 Topfield 8080 8080 80 80 192.168.2.111
7 https 443 443 443 443 192.168.2.110And that's exactly what your latest logs show.
TheEther
Jun 12, 2016Guru
Go to your ReadyShare settings and turn off https access.
buchtik
Jun 12, 2016Tutor
All line in Readyshare denied, router restart:
[LAN access from remote] from 52.163.94.221:35396 to 192.168.2.111:80, Sunday, Jun 12,2016 22:01:01
[LAN access from remote] from 52.163.94.221:38803 to 192.168.2.111:80, Sunday, Jun 12,2016 22:00:53
[LAN access from remote] from 52.163.94.221:56084 to 192.168.2.111:80, Sunday, Jun 12,2016 21:59:58
[LAN access from remote] from 83.248.8.14:22625 to 192.168.2.110:443, Sunday, Jun 12,2016 21:42:37
[LAN access from remote] from 83.248.8.14:61861 to 192.168.2.110:443, Sunday, Jun 12,2016 21:42:37
Warning!
I solved the problem before 2 years - with headquarters support Netgear for 6 months, but no solution to the problem. (Including sending the config file ... et cetera.)
I this time come new firmware - no solution.
