buchtik
Jun 12, 2016Tutor
Port Forwarding - communication outside of the rules
Can someone explain to me - the external communication (no asked) outside the rules of redirection to LAN network - the firewall does not work ? Port forwarding rules: 1 DMS B ...
- Jun 12, 2016
Hang on, you have two port forwarding rules allowing ports 80 and 443 through.
5 Topfield 8080 8080 80 80 192.168.2.111
7 https 443 443 443 443 192.168.2.110And that's exactly what your latest logs show.
buchtik
Jun 12, 2016Tutor
All line in Readyshare denied, router restart:
[LAN access from remote] from 52.163.94.221:35396 to 192.168.2.111:80, Sunday, Jun 12,2016 22:01:01
[LAN access from remote] from 52.163.94.221:38803 to 192.168.2.111:80, Sunday, Jun 12,2016 22:00:53
[LAN access from remote] from 52.163.94.221:56084 to 192.168.2.111:80, Sunday, Jun 12,2016 21:59:58
[LAN access from remote] from 83.248.8.14:22625 to 192.168.2.110:443, Sunday, Jun 12,2016 21:42:37
[LAN access from remote] from 83.248.8.14:61861 to 192.168.2.110:443, Sunday, Jun 12,2016 21:42:37
Warning!
I solved the problem before 2 years - with headquarters support Netgear for 6 months, but no solution to the problem. (Including sending the config file ... et cetera.)
I this time come new firmware - no solution.
TheEther
Jun 12, 2016Guru
